Fenzed Cube is a tribute to the Chinese puzzle designer known as Fenz. Fenz has been working on several puzzle designs with looks and geometries very similar to this one, in particular Fenz Bermuda Flower. The geometry of Fenzed Cube is in between a cube and a tetrahedron. The dihedral angle between the four faces is around 100 degrees (90 degrees for a cube, 109.5 degrees for a tetrahedron). The geometry is also similar to Distorted Cube, albeit that one has a dihedral angle of 92 degrees, and two more faces are made to turn via fudging.
