I am about to order a machine part that needs to fit.
Looked at this
https://i.materialise.com/en/3d-printing-materials/high-detail-stainless-steel/design-guide
Increased the hole portions of the model to fit by 5% per the recommendation
in “Dimensional accuracy” this section
The model is just a 5mm shaft (43mm length) with a 10mm D hole (3mm outer and 2.5mm flat section)
The hole is for the shaft of this motor.
Would the printed model fit?
Shrinkage compensation for high detail stainless steel
Thank you for your interest in our service.
First of all I would like to emphasize that we can not guarantee the dimensional accuracy.
If you still want to give it a try please provide us with the file of your 3D model you would like to print.
It will be easier for us to evaluate it.
Please send the file to: https://imaterialise.helpjuice.com/contact-us?contact_query=Please%20enter%20your%20question
With the subject which will help us to understand that this is your model for checking.
Thank you in advance.
