What are the tolerances for press-fitting a metal nut into my design? I will make a 3 mm deep pocket to a 5 mm thick wall and want to partially embed an M3 nut into it. The nut will be embedded by 3 mm of its height and the wall will remain another 2 mm thick behind the nut.
My question is for width tolerances. The M3 nut (DIN 917) is hexagonal and has a width of 5.5 mm (see “s” on the image). What width of the pocked to I need? I want the nut to nicely hold in place even with vibrations etc.
Here are dimensions of my nut:
