Matériau étanche à la pression d'eau
Bonjour,
j’ai conçu une boite avec couvercle et joint torique: quel est le meilleur matériau étanche à la pression de l’eau ?
merci
Thanks for the question. Our customer support is only English/German thus having used a translator I will reply in English.
It is possible to print the models in Polyamide SLS with Waterproof finish. The finishing is great for testing or decorative needs, however we can’t guarantee it will withstand constant interaction with water.
