Hi all,
I am designing a small computer case with vents on the side. The vents are made up of little equilateral triangles with side lengths of 1.5 mm (see image below).
I have ordered prototype SLS prints from another service of two different versions:
Version A has a wall thickness of 2.05 mm.
Version B has a wall thickness of 3.5 mm.
Version A came out well, the vents look good. However, for version B, powder was stuck in the vents when it arrive.
I can’t tell if I should adjust the design (either by increasing the triangle size or decreasing the wall thickness) or if this is due to insufficient cleaning by the producer of the prints for version B.
I would like to order MJF prints from i.materilise, and would like to know if I would have the same problem. Ideally, I would not want to change the design as I would like the walls to be as thick as possible, and the triangles as small as possible.
Any input is greatly appreciated. Thank you!
