Gray resin drain hole placement
Hi, wanting to make sure my model is compliant. My object is essentially a short, thick tripod. Can I get by with drain holes in only two of the legs? This would be preferable. In this configuration, the hollow space inside the model would connect all the legs, but you would probably have to tip it to drain the third leg, right? Is this acceptable?
Thanks!!
I would kindly ask you to send us the file with your 3D model through the Conact page: https://i.materialise.com/en/contact
This will help us evaluate the feasibility of the model.
Thank you.
It looks like that requires an order reference number, which I haven’t got.
You do not need an order reference number. You can send the 3D-file through the contact page or make a price request.
I just sent you a direct message with the e-mail address where you can send your file.
