I’m designing a watch dial to be printed in 3D with your High-Detail Stainless Steel.
For this project I will need to insert small feet (or pin) in small holes, on the dial.
I would like to know if I can make a “press fit” attack and possibly what is the tolerance to have a correct fixing.
Considered that the diameter of a foot will be 0.75mm.
Will the hole have to be 0.75mm too?
Or will it have to be a little wider to allow the insertion of the feet?
Eventually, how much wider?
Thanks!
PS: I add a question: for this kind of product do you this is better High-Detail Stainless Steel or Copper?
Copper is smoother?
Steel is more detailed?
Thank you!
