I am thinking to print some chainring spacers for my bike because the size is not available commercially. It’s a simple ring approximately 12mm OD, 10mm ID (1mm wall), 3mm high, with 0.25mm edge chamfer. I need the 2 sides to be parallel. Connecting support structures or sprues for infusion is ok on the cylindrical side, but not good on the flat top/bottom.
Which material is suitable and most durable under load?
I think the possibilities are:
Stainless Steel (has sprue, possible dimensional shrinkage)
High Detail Stainless Steel (conflicting information on material page, one says SLM (would have support structure), other says jet head with binder (video shows no support structure with flat parts, printed directly on plate))
Brass
Bronze
Aluminum (support structure, cut off from base)
