I’m going to try to make a sort of waveguide in the transparent resin and I note that a varnish will be applied after the build. Are the parts “shrunk” to compensate for the thickness of the varnish, or should I compensate in the model?
Also I think I have an idea of the best build direction but am having difficulty in STL export from solidworks. No matter what orientation I output the part, it exports flat! Is there a was to specify build direction or do I have to fight some more to get the STL rotated correctly?
