Printable in Brass with Rosegold finish?
Hello!
I would like to print this necklace.
In brass with rose gold finish…
Can I print the inset ring as well?
Kind regards
Sascha Bonneß
https://cad.onshape.com/documents/572f5930f6e9606d7d7884f2/w/034b7bb9413bf0ebae27a2ad/e/29612ebf450a0cc6f206086a?renderMode=0&uiState=62b1a37cf535993239e30b8f
Dear Sascha,
Unfortunately, your model is not feasible in brass. Nested objects (objects floating within another object), hinged parts, and interlinking parts, such as chains, cannot be made with lost wax casting.
Also, walls of your model are not thick enough. For most models in Brass, the minimum wall thickness you can use is 0.6 mm for the natural finish and 0.8mm for the gold and color plated finishes.
You can find design recommendations in our design guide for brass: https://i.materialise.com/en/3d-printing-materials/brass/design-guide
