Parts of the print missing
Hi well… This was my first order with i Mterialise, and im not too happy to be honest…
On a couple of counts.
First main issue… My model was a grouped model following the guidelines in the FAQ… I had 3mm thick support between some of the parts and main model… 2 of these parts are missing… 1 Button and a Rocker switch…
It seems pretty clear they got broke during the cleaning process because I had the black ink job done too and the ink is covering where the parts were… If it had broke during transit the bits would look grey where it broke.
So this is a QA thing after printing, so… not cool. I have placed a support message but Im posting here as well because i dont want this over looked. I need this corrected. And given this is your QA process going wrong I-materialise should be covering the cost to correct this.
The other little issue is layer lines. Im not new to 3D printing, I print at home as well, so I know layer lines is a thing… But in the production print house such as I materialise, the engineer who orientates the parts should be doing so that best reduces the appearance of layer lines across curved parts, instead it appears the engineer has orientated my design to maximise the appearance of layer lines in the curved parts… This is just lazy. Im not sure how deep the printer tub is, (though I did see the machine that was used to print this at TCT yesterday), but if my model was printed just off from vertical the layer lines would have been near invisible.
So, so far for an order that cost just about 130 quid, im not too impressed at all.
After inspection of this, we were going to make slight changes to the design but then put in an order of 10 units… Im not sure I can trust I-materialise enough to provide consistently good prints, if the QA work is as bad as this.
QA = Quality Assurance also known as QI = Quality Inspection…
Hello Simon, thank you for sharing this issue with us. Could you please let me know about which order we’re talking? If you could give me the IMC number I could check who was your customer support officer and take it up with her. Kind regards
Ive only made one order so I would have thought that be pretty obvious, but ok
IMC129243
Main.stl a button and a rocker is missing… I have already contacted customer support and gave them a picture of the print vs the cad file and circled whats missing…
Hello Simon, there was really no way that I could now that Simon.Mangy_Dog is the same person as the name in this order. I noticed that my colleague Esther has already send you an email and you replied with a picture from the missing parts. This picture shows indeed which parts are missing, but there is no picture from the layer lines. Could you please send us by email also a picture that clearly also shows that problem? Would it be ok for you if we handle your complaint further on the normal way (by email with your customer support officer)? Kind regards Lizy
My main issue is the missing parts… The layer lines is secondary…
Oh Also sorry, i had assumed the forum accounts were linked to the shop account…
Hello, no problem. As my colleague is not in the office, I will have a look and answer you by mail. Kind regards Lizy
If you can be quick as we are approaching the deadline to deliver the project. And i need these pieces to test with before putting in the main order.
