Hello imaterialise.
I have used your services before but have typically only worked in the “steel” option. I have found this very good.
I am considering having some little gifts printed in silver. These gifts may include text. I have a few questions:
- What is the smallest font height (in mm) you can reliably print in silver?
- Would you recommend the text appears as an extruded cut into a surface or an extruded boss off of the surface?
- What depth/height would you recommend the text feature to be into/off the surface of the part?
Many thanks,
George
