Hi Dmitriy,
I got “The model was not found.” when I use link.
About the surface (it’s hard to explain in english for me, but I’ll try). As I understand, the perforator tool has “thickness”. I mean not how deep it goes, but there is “distance” from the model surface and the end of the parfarator, this green hole, that you can see in img. I don’t know what the distance is, but let’s say that one millimeter. And if the surface is uneven, and as I understand it, it counts from the center (I’m talking about this 1mm), if the edges have more than one millimeter, then the perfector tool simply don’t go through. That’s why I ask is it posible to extrude this parfarator tool? Make for e.g. not 1mm, but 2 or 5mm.
Just look again at that picture that is transparent. You will see that the edges of the surface are taller, and the perforator of the length of the tool is not enough to remove the entire surface. As I mentioned, it’s probably due to the fact that this tool counts the thickness of its wall from the center.
I’m sorry for my English.
Thank you
