How can I be so sure about the quality of print for my model?
Hi there,
I’ve designed an Ankh symbol with some hieroglyphs on it. I want to 3D print in with Steel, gold plated, polished. The size is 92x8.3x151mm and it loads perfectly here.
Those hieroglyphs symbols on the body of Ankh are tiny, so how can I know if the created model is good enough for printing with steel.
Thanks,
As far as the engraved text and surface details for steel are concerned, these are the rules that you need to follow : For engraved text or surface details, we recommend letters with a minimum line thickness of 0.8 mm and a depth of 0.8 mm. For embossed text or surface details, we recommend that letters have a line thickness of at least 0.8 mm and a depth of at least 0.8 mm.
If you place your order and we notice some issues, we always inform our clients about it.
Hopefully I gave you enough information to complete your order.
Greetings
Thanks Esther,
It was enough and its very good that you will inform clients about the possible issues.
I’ll put my order soon.
