How big are the samples
I wanted to buy some of the bronze samples but wanted to know how big there are. Also are the ridges on the front only? And is it flat on the bottom?
Thanks
Hi there,
The size of the bronze sample is about 1.5 x 1.5cm (it is standard for precious metals). As for the ridges - yes, the face of this sample is ridged while the bottom is kept flat.
Customer Support team
thank you
Also is it possible to ask for the polished bronze without a PU coating?
Only polished PU coated bronze is available for ordering. If you need it without coating, please add a comment to the order about this during last step of checkout procedure.
Tetiana
Customer Support Team
