High temperature material needed
Hello guys,
I’m in need to make a 3D part with your Steel material but I’m not sure if it fits my needing.
The part has to stand a temperatures around 900 degrees Celsius. Is it possible with this Steel that you provide here? In your main page you mentioned that the steal is 316L witch will stand this, but idk.
Thanks
Hi there,
It actually depends on your application. I general, grade 316 stainless steel has the melting range of 1,371 °C – 1,399 °C.
If you intend to print for a specific end use, feel free to check with our different department that prints in an industrial environment - OnSite. You can get more insight about 316L Steel and also get an instant quote here
Please note that i.Materiliase guarantees the decorative use of the 3D printed models with us, the utilitarian and functional intention of prints is solely at your discretion.
Customer Support team
