I’m using OnShape 3D mechanical software. Designing a simple panel for electronics instrument with 2 colors. The base color and raised text colors. Using OBJ file format. The upload says I have wrong volume. OnShape says otherwise.
Thanks
Thanks
I use the .STL file format and it works good.
Uploaded model might be too small. Please check your export settings. After uploading your file, you can check actual dimensions of your model and rescale it if necessary.
