Hello. I’m brand new to 3d printing. I designed this piece to be printed from the bottom up using what I believe is called “FDM”; however, I thought I read that the “MJF” printing process does not require overhang supports. Did I read that correctly?
If so, by using MJF, can I add these two red squares to the bottom of this piece without the need of supports? The red squares will be mating tabs so I still need the bottom of the main piece to be completely flat. I hope I am making sense. (I know very little about 3d design and printing). Thank you.
