Is anyone else having this same problem? I have a custom scene that I load under build preparation before bringing in an STL file of a part that I want to print. I am having an issue when I bring the part in it isn’t going to the default position for the Z-axis. The default position of the part is 6.5 mm with the bottom of the scene being set to 0 for the Z-axis. When it is at 6.5 mm the part is below the bottom part of the scene. This issue just came about when I had to update to the latest version of the magics. Prior to this we never had this issue. Any ideas how to fix this?
Thanks
