Coin Maze is a mechanical maze. The object is to remove the coin from its cage. The coin has a maze on each side. The maze pattern is based on the logo of the Mazemaker company of Adrian Fisher. Whereas the maze pattern looks simple, the actual maze is harder. This is because one also have to shift the coin forward and backward. Effectively, one can jump over a wall at some point, whereas there are invisible walls at other points.
