Hi there,
I am considering using steel to create small ‘cookie cutters’ that can cut out shapes out of clay for a ceramics jeweller. I have previously made them out of PET plastic which has worked great, but PET requires relatively thick walls and is not suitable for small shapes.
I have created two models based on your steel specs, both with 1mm walls. However in Model 1 the wall gets thinner to .8mm at the bottom whereas in Model 2 it gets down to .2mm (which is preferred).
Link to both models: https://we.tl/t-hjTgA0O7yW
I’m aware your guidelines mention a minimum detail thickness of .8mm for steel, is it possible however to go down to .2mm? I’m asking this because it is only a small part of the model less than 1mm in height where it would go smaller.
Is the steel prone to rust when using with clay and if so is there a specific coating that will help? (which will be slightly moist)
Is it possible to use my Dutch VAT code in checkout but send the order to the UK? I am Dutch and live in London, but you do not get a VAT code as a freelancer in the UK. I am registered as a freelancer in both countries however and have a Dutch BTW code.
Warm Regards,
Twan
