Hi. I am trying to produce some parts for a locomotive model. I’ve tried sending my first drawing to customer support but the enquiry system won’t work without an order number or an offline quote number but I cant work out how to generate the latter. So here are my questions.
Scaling the prototype will produce web thicknesses of less than 0.5 mm so I have adjusted them to 0.75 mm. what is the minimum recommended thickness or aspect ratio.
I have assumed a machining allowance of 0.5 mm n mating faces but this may not be necessary. Assuming you add a shrinkage allowance. How accurate are the parts after casting.
Some of the parts I need will have voids or cylindrical holes. These would normally be achieved by inserting ceramic cores into the wax part. Is this something you can do or do I need to break the assembly down into smaller parts.
John Chadwick
