I plan to print a model in bronze. I have lots of subtle texture, and don’t know if it will show up in the final print. The model is is about 2’’ in size. Does the casting process smooth out the bronze?
I want to print a cheaper plastic test print before I do it in bronze so I know how it looks and if I need to add more texture for it show up in final print.
Which plastic should I use that would be a good approximate what the bronze print will look like?
Also for polished bronze, can you polish only parts of a model that I specify and not the whole model?
